Root question on sbf for GB
Hey everyone,
This may be a dumb question but I would like to see the reasons why. Everyone is stating you need to SBF back to stock .340 froyo then go to GB. I was wondering why can't maderstock be used since its and sbf file turned into a zip file for doing the same exact thing as a SBF file would (going completely back to stock).I am not talking about using a leaked GB I want to know if this will set me up for using TBH's files to get to GB.596
It doesn't make sense to me either. But a lot of people were having problems when going from a froyo rom --> maderstock --> GB leak. I would assume you would have the same problems everyone else is having when going to OTA. But look at it like this. You could try it and save yourself the SBF step if it does work. Or if it doesn't you will have to SBF anyway.
well knock on wood I never had to sbf before and I really dont want to to just go to gb since the X is running fine. I may just do it and get over it. still thinking about it.
everyone has had NOTHING but problems...every single person i know of that has used maderstcok to move to Gingerbread has had problems and needed to SBF anyway...
What's there to think about!?!:p GB >>> Froyo. SBF’ing the Droid X U D G
That link is the end all solution with instructions and files for SBF'ing your phone. Which operating software do you have on your comp? Windows, OS X, or Linux?
I read that when preforming the 3 file install to .588 or the 2 file install to .596 the starting firmware/system apps/boot img/radio has to be exact .340 or the process will derive errors. Maderstock does not revert to complete stock.
thanks for that piece of the answer. I was looking for this. Now I now for sure I need to sbf back to stock to move forward. thanks again
do you have the device set in SBF mode?
you're in GB, right? So you need to turn off your device, press the up and down keys for volume at the same time, and then push power. Hold all three until the screen flashes, you can let go and you will see:
Bootloader
30.XX
Battery OK
OK to Program
connect USB
Data Cable
Then you can attach the device to the computer via USB cable and start RSD lite.
Bootloader
30.XX
Battery OK
OK to Program
connect USB
Data Cable
Isn't it volume buttons + camera button + pwr?
nope, but it won't change the way it works.
all you need is up-down-power (that didn't sound right...)
I always check before I post on those things, since they change so often. This worked on mine, and I'm on GB, must be right...
Good luck! I just did my first SBF after trying to install gingerbread over maderstock and it bricked my phone. Google became my bestfriend!
There have been many posts telling people they should NOT try to install GB over Maderscok, why you would do it, (or try to) is beyond my comprehension.
Cool down, Bugly, it'll be OK...
SBF back to .340, then load GB from one of the options TBH gave. Easy enough, there are NO shortcuts, you are NOT the one guy that will get it to go without following the proper steps.
Wait, Bugly, you're getting heated again...
Seriously, just follow the steps given and it will work.
I wonder if Moto changed this since the X2 doesn't have a camera button. .
For me I was trying to take the easy way out without having to mess with my crappy computer and SBF'ing. I have tried to SBF once before and had nothing but problems with my computer and getting the drivers, RSD lite, and the phone to work. I honestly didn't see anything about not installing over maderstock. I actually did see a post where somebody "guess" it would be ok. But I learned the hard way and had to deal with my issues and get the SBF to work.
Sorry, I was kinda abrupt on that, but I've been fielding that same comment all day on this and other forums. The only way to get it done smoothly is to SBF to stock, or "upgrade" from another GB.
No issues. Just felt like I had to explain myself.
Bootloader
30.XX
Battery OK
OK to Program
connect USB
Data Cable
Bugly,
I am still on froyo running apex 1.4.1. looking to choose the correct upgrade path to get to rooted .596.
sorry, man, you're gonna have to SBF from Apex. There is no way I know of to go straight from apex to GB. If I'm wrong, I'm wrong, just haven't seen it yet
596 is a system only update so needs a very clean froyo to update.
I had to format data after sbf'ing to froyo (from 573) just to get it to boot. :D
