T
travelcat
Guest
I'm looking at eventually installing A2SD+ onto my Desire, and I understand I'll have to partition the 16GB SD card first. SUroot's instructions suggest using GPARTED, which I've downloaded, but I also found this page that suggests loading Amon Ra recovery, and using it's options to partition the card properly for A2SD+ use ...
My custom recovery is 4EXT, which can apparently do the same thing.
So my question is - what are the risks and advantages of taking what looks like the easier route, and just partitioning in recovery, or why should I use GPARTED for this task despite the availability of partitioning in recovery?
(For those who haven't been following my other thread, my Desire is Froyo 2.2, S-OFF and I'm about to load a pre-rooted stock ROM with init.d so I can do this. The whole reason I'm going through all this trouble is to get more room for apps on my phone.)
