YankeeDudeL
Android Expert
Auto orientation annoys the crap out of me. I prefer to turn it off, however, I still want a way to have it on for viewing pictures (i.e. in the gallery or Facebook app). Is there any way to do this?
slide your keyboard out
no other way that I know of
I'm not sure about the other launchers, but Sweeter Home 2 preferences let me disable auto-rotation in the home screens, but in system settings>display, I have auto-rotate screen enabled, which allows auto-rotation in the browser, gallery, etc.
YankeeDudeL...If you're using LauncherPro (which is what I have) it is possible to do exactly what GirLuvsDroid said. I was aware of the auto-rotate option with the LauncherPro settings, but not within the android OS itself. I turned off auto-rotate in LauncherPro (it's found in the Behavior settings of LP) but then went to Settings>Display and made sure Auto-Rotate Screen was checked. Now the home screen itself doesn't rotate, but the browser, gallery and other apps that support this feature do.
