Root Questions about Froyo SC
smauldin
I'm running SC EB01 with 2.6.32.9 kernel, and I've noticed that I'm getting significantly less signal compared to stock 2.1, and my bluetooth is having trouble staying connected, or remembering settings. Is there something I can do, or is there a better ROM for these?
Thanks all.
Thanks all.
Do you also have the EB01 radio? Also BT wise SC is probably your best option as other rom's like AOSP dont even have fully working BT
Thanks. How would I check which radio I have? Actually, I can't even remember which version of SC I flashed. Should I upgrade that as well?
on eb01 you should be using the eb01 radio...go into settings->about phone and whatever your baseband says is your radio
