Hi
I have read a few things about MMS on the SGS2 but try as I can, I don't seem able to send or receive MMS messages.
In the past I have been used to sending pictures with a message and the device automatically resizes them to comply with the Network's limitations. Receiving was automatic. If I try to send a picture the program doesn't attempt to resize - either the Stock message app or GoSmsPro either.
It seems that to send or receive MMS messages on the SGS2, you need to activate Data Network Mode - is that correct? If so I can understand that for sending but receiving? - do they just get lost in the system somewhere, if for example, someone sends you a MMS and Data Network Mode is turned off?
I tend to keep mine switched off to conserve the battery and also because I have only a limited monthly allowance data-wise. So what happens in that scenario please?
Finally I need to check my settings. My phone is a Sim-free (CPW) phone running ICS 4.0.3 I am on Vodafone UK. Could some kind person let me know the settings please and try to answer my questions - I would be more than grateful
Cheers
Cheers
