Okay I see it now, thanks and is there any way to get the on-screen buttons like the GNexus?
Why would you want both hardware and soft buttons?I think that would just take up too much real estate on the screen
Also when I flash another ROM or anything like that, is there anything I should do since I partitioned it? For roms that arent a2sd enabled, you will have to flash this to enable it
If I get a new SD Card and move all of my stuff over, do I have to re-partition it?
You dont have to partition anything, but if you want a2sd to continue working you will need to partition the new card
And lastly do I have to flash a2sd roms only or does it matter?
No, it does not matter
The status bar always says I have a voice mail.. It says " New Voicemail (1)" and then below says "dial (my number)". The problem is when I hit it, it sends me to my voice mail however I dont have a voice mail. This is a problem for me on every aosp rom that I have tried and I have never found a "cure". Does anybody know how to fix this?I keep forgetting there are 2 cm9's. i am not having that prob with the cm 9 by team dirt.
not having it on decks reloaded either.
Hey guys, I still have one more problem that it seems like I have on every aosp ROMThe status bar always says I have a voice mail.. It says " New Voicemail (1)" and then below says "dial (my number)". The problem is when I hit it, it sends me to my voice mail however I dont have a voice mail. This is a problem for me on every aosp rom that I have tried and I have never found a "cure". Does anybody know how to fix this?
