Root Quick question
masully1984
I want to install the alternate battery that is shown here.
REVOlution 1.2r1 ALT BATTERY
I'm still fairly new to rooting and all the modifications, I just need some help to make sure I'm going about flashing this the correct way. Do these steps sound right? I already have the zip file located on the sdcard in the main folder.
Turn your phone off.
Press and hold the Volume Down and Power at the same time to boot into HBOOT.
When the white HBOOT screen appears, use the volume button to move down to
You won't get the "triangle" when you enter recovery. Since you're rooted, it'll open Clockwork instead (custom recovery). You'll just install from SD, choose the file you want to install, and that's it. Once it's installed, press power button to go back one menu (if needed) and select reboot.
Might also mention that in Clockwork, the power button is the "back" key and the trackpad button is used to make a selection. Also, I'm hoping and assuming you have done a nandroid backup by now. If not, do one in Clockwork before loading this thing just in case anything goes south, you have a safe point to return to.
