Alright, generally once you get the drivers installed correctly, the bootloader unlocks quite nicely. What happens whether you do it through a toolkit or manually is that you boot the device into fastboot mode(bootloader interface) and the command "fastboot oem unlock" is issued using the sdk tools provided by Google. After that, reboot the device and it's unlocked.I plan on using roms in the future. I've rooted and rommed on other phone(s) before, but I just mean do I unlock the bootloader FIRST, before rooting and romming?
Generally toolkits will provide them for you. As for toolkit, I always tend to suggest Wug's Nexus toolkit for people with Windows because it's a lot more user friendly than others I've seen.So I have to have the sdk tools from google to use ncry?
Thanks. I successfully unlocked my bootloader, rooted, and installed a twrp.
Now, I want a rom where I can get rid of the bottom buttons, have pie controls and also make the top pull down bar still there, but transparent, what rom would this be possible with?
Can you explain the difference between like aosp, hybrid, and aokp?
Also the difference between deodoxed and odxed or whatever
Okay I'm installing PAC right now. Now I backuped my apps in titanium backups, when I install the new rom do I just download titanium again and then my apps will be there to restore?
