Help Quick Settings - notification bar
AG0607
Hi all,
Just wondering if anybody can help.
My quick settings on the notification bar for things such as bluetooth, wifi, aeroplane mode etc has disappeared.
When I drag my menu bar down there is now just a black space where those options used to be and if I go into my settings to change the buttons that would be visible, there are no options there for me to select.
Anybody have any ideas as to why this would happen?
Hi guys,
Sorry to bump the thread. Just wondering if anybody has any suggestions how I can get this back?
Thanks.
Hi AG. I'm not sure why they disappeared but you can go to settings > My device> display > Notification panel. Hold your finger on the icon you want and drag it to the top of the screen.
If you keep having the problem you might try a factory reset.
