sharksfan7
I'm about to flash Android Revolution. The devs recommend a particular radio (12.62.60.27_26.13.04.19_M) but I first want to see how it works with the stock GB radio I currently have (12.56.60.25P_26.10.04.03_M). So I assume I need to flash the corresponding RIL for it. Will doing this overwrite the RIL for the recommended radio that is cooked into the ROM? If I decided to then flash the recommended radio, would I then need to also restore the corresponding RIL? Or can there be more than one RIL available on a ROM at the same time?
Thanks.
Thanks.
