spyder
OK, I realize that there are a few threads with similar titles, but the content is different, each of those is normally in regard to the use of task killers and apps starting in the background, which is normal with Android (filling up the memory).
My issue is quite different. First I do NOT use a task killer or anything of the sort. I am running Icarus 1.1 on the Ascend.
What I've noticed lately is some apps starting up on their own? At first, I thought I was bumping a button or something, since alot of the ones I refer to, I have screen Icons for.
Like say, calculator for example. I was going across the screens. Put the phone down, looked over in a min or two, and for some reason, in was on the calculator.
Another, is the Alarm Clock. Now I do use it alot, so I'm sure it's in the memory all the time. BUT, very often, I'm backed off to the main screens, and outta no where, Alarm Clock app has started up?
I won't be so ignorant as to say I am NOT doing anything that incourages this, but I really really don't think so. It truly seems as though these apps are firing up randomly.
One other would be the stock browser.
Anyway. Any thoughts or comments would be appreciated.
As I said I'm aware of the other threads talking about apps starting up alone, but those are in the background, which is perfectly normal behavior for the Android system.
BUT, The app actually starting/running on it's own is totally outta left field...lol....????
Totally confused....Thanks in advance for anyone with thoughts or commdnts, or an actual "what's going on" info??
Thanks again,
Jeff / Spyder
Thanks again,
Jeff / Spyder
