I had thr random reboot bug last week as well. I was told it *could* be light flow and i should uninstall that. (I did.) Mine seemed to happen while using wifi, and I also read that wifi bootlooping is a known issue and that currently the only fix was a factory reset. (After backing everything up to Google that can be backed up.) With the subtraction of light flow and the reset, I have yet to experience it again.
Coming from an iOS user (iPod Touch, iPhone, iPad), this is a really annoying problem. None of my iOS devices had ever randomly restarted.
I do have light flow installed. I wonder if removing it would stop the random restarts/crashes? It could be a change of signal as others have mentioned too. I've had about 3 restarts all in the same general area and it might be where the 4G/3G line is.
Can anyone else testify to restarts at 4G/3G lines?
