Root random sprint question??
If you successfully root your phone and do nothing else to it, you wouldn't be able to tell the difference in everyday operation. Rooting gives you the ability to mod the phone, but if you don't mod it, it's still the same phone, just unlocked.
No offense in saying this is intended, but if you need to ask that then I suggest you spend some considerably more time reading about rooting before you actually do it. These days it is so easy to root that it can be easy to get in over your head.
Just my recommendation.
I know..it gets bumped to the second page and people don't realize it is there.
I am in permanent copy past mode today lol
I think I will start bumping it daily to keep it on page 1
