I installed it a couple days ago and a few times during the day the screen will become unresponsive at the lock screen.
I am forced to hold the power button untill the phone reboots. Anyone else with this problem?
I had the same problem - and ended up doing a factory reset. I got everything set up again in about 30 minutes and it's really smooth now. I also gained about 400MB of free space which I needed since I'm not rooted anymore. I think I'm going to wait on rooting. I almost never tethered, and I don't really need the space. I keep most of my big apps on my Nexus 7 and I always have both of them with me.
Yes, but I thought it was just me because I rooted my phone. Rooting was my first objective once I obtained the updated. Since I have noticed the screen issue and have to reboot the same way as you mentioned. Since I have a case it is easier than a battery pull.
Hey framirezferrer,
Could you post a link to that FOTAKILL?? I've only been able to find Ver. 1 of FotaKill and it doesn't work to stop the NAG upgrade PopUp.
Thanks,
Rob
UPDATE: Since installing the Nova launcher on the day of my original post, I have had no more instances of the touch screen lockup. That being said, I wasn't seeing it as often as some others, so it might be too soon to tell.I'm having the same problem, but less frequently (twice in 3 days). I've never rooted, or done anything other than download a few apps. I'm going to try the Nova launcher suggested above. I'll report back
I'm having the same lock screen freezing problem. At least twice a day. With and without headphone use for me. Can only restart with battery pull. Did factory restore, but didn't help. Someone had mentioned trying an alternate launcher (meaning touchwiz might be the problem), so I installed the free Nova launcher from the Play Store last night. So far so good, but I'm not sure it will last. This has shaken my faith in Samsung/Virgin/android in general. Phone was great before the update.![]()
Disable Google Now. It was the solution for me.
Thanks for the tip mrg666. Glad to see you in the Reverb forums as you helped me a lot with my Opt V!!
