Root Raw camera
Wow.
Elle Stone from Nine Degrees Below said:
Hi EarlyMon,
I was just working with your raw file. GIMP is assigning the built-in sRGB profile because there is no embedded ICC profile. Your dcraw command line told dcraw to output a linear gamma image ("-4").
Essentially your GIMP curve is counteracting the effect of assigning a regular sRGB profile to a linear gamma image. Your raw file really isn't underexposed at all.
The regular sRGB profile has a more or less perceptually uniform TRC. Your dcraw output assumes a linear gamma TRC.
If the idea of an ICC profile TRC (tone reproduction curve) seems odd, given your background you might find this article the quickest way to assimilate a lot of relevant information, and there's a section on TRCs:
Completely Painless Programmer's Guide to XYZ, RGB, ICC, xyY, and TRCs
http://ninedegreesbelow.com/photography/xyz-rgb.html
I attached a linear gamma sRGB profile for you to experiment with.
Alas 8 bits isn't enough to work with linear gamma images. So either compile GIMP 2.9 from git (easy to do, and Partha maintains a build for Windows and also I think Mac, I can send you the link if you are interested). Or else remove the "-4" from your command line. Or experiment anyway, but you'll see bands in the shadows from posterization.
And it goes a long way from there, including not needing -m 40 because there's not a lot of noise in the images to begin with. :p
Ok - back to the drawing board.
Yeah, that blew my mind!
I'm reading the color article now.
We need to remove -4 until we see Gimp3, thats unless you compile a different version? Don't really know what that was about there.
I'll try and play around today if I can find time. Yesterday was a wash for me. :o
I mentioned that GIMP could only process 8-bit layers, and she responded that I could do better.
I can't believe that I got so lucky on our two pictures but it really was luck. :)
I did a new dcraw output using these parameters:
Code:
dcraw -v -4 -q 3 -m 40 -T -a -r 2.132583 1 1.480864 1 IMAG0003.draw
Here's the pooch photo edited with RawTherapee, 16bit .tiff output.
Here's the full file: https://drive.google.com/file/d/0B1xiIlbIPKFDUm8xU19CajIwSFU/edit?usp=sharing
Still need to read and mess with all of the options (there are a lot of editing parameters!), and learn what I'm doing instead of just moving sliders until it "Looks Good". :o
Still a little on the dark side, need to mess with the dcraw output to get a more exposed image.
Oh, hell yes! :)
I was leaving that in there for editing in RawTherapee, but this is much better.
So the -4 assigns a 16bit linear curve, without it we're reduced down to 8 bit. Why does it make the image so dark though? Seems I need to do some more reading, because I'm not understanding entirely.
Oh, hell yes! :)
-4 outputs linear gamma output and 8 bits is not enough to deal with that, and besides, it conflicts with the sRGB model that we're using for post-processing, according to Elle.
Furthermore, she went on to say, when we remove that, we see that the images are not underexposed at all.
-6 gives 16-bit layers, Elle said that -m 40 seemed unnecessary given that the images didn't look noisy - I couldn't resist, so I went for 10 iterations on the -m.
Note that -4 = -6 (16 bits) -W (suppress lightening) -g 1 1 (linear gamma)
And -q 3 (AHD interpolation) is the default - which I had stuck in my head wasn't, so just leave that off.
So, I did -
dcraw -v -m 10 -r 2.132583 1 1.480864 1 -6 -T IMAG0003-puppy.draw
Result, with no changes or edits -
Actual tiff - https://drive.google.com/file/d/0B2MPU5MqABTXbWNWdXBJcl9rQmM/edit?usp=sharing
And I believe that you'll find the above is the same as -
dcraw -v -m 10 -r 2.132583 1 1.480864 1 -6 -T -H 2 IMAG0003-puppy.draw
Where -H is the highlight modifier.
Here's a recap of the heavily processed photo from post 50, followed by the same using -
dcraw -v -m 10 -r 2.132583 1 1.480864 1 -6 -T -H 2 IMAG0007.draw
I think the additional sky detail makes it pretty obvious that Elle was only 100% right (thank you Elle!).
Here's the full tiff of the second one, no other processing done.
https://drive.google.com/file/d/0B2MPU5MqABTXemRnWHJQdURReWM/edit?usp=sharing
Note - the building was shot with +1 EV because I'd thought from last week's trials it would need that. So, that's why it's a bit overexposed.
Is there a 32-bit version of dcraw for windows? I'm trying my hand at this with my One SV (using the one s camera) I end up with a .draw file but I can't attempt to decode it since the computer I'm borrowing is old and 32-bit
PS - sorry for hijacking your thread I tried searching the thread(s) but all of my key words aren't long enough :o
Nonsense from last week, followed by the new parameters (and no other editing).
And that ends my playing around with that building (and the crowd goes wild! lol).
Next time - more interesting subjects and I'm going to try my hand at my own color adjustments.
I'll be shooting some white stuff for reference, and just passing through dcraw with the -a param and seeing what r numbers it turns that into.
^Pro tip from Elle, fast way to get zero'd in just a bit until buying an IT8 test card.
Do you have access to a compiler on that? I might be able to help you build one if so.
And if not - if you want to lay your draws on me, I'll give them a go for you.
Other option - got a fair sized spare USB stick handy?
How are you with Ubuntu?
The other option is to boot 32-bit Ubuntu from a live USB and go from there. It will be some work and a bit more if you're new to Linux.
PS - no worries on the hijack. :)
I was studying the dcraw commands this after noon when I got called away. Can you believe they want me to actually work during work hours! Incredulous! :p
I'll give these parameters a go with the slew of other .draw files I've collected. I'm sure everyone is also tired of seeing the same photo of my pretty puppy. :D
We could quite possibly tweak the parameters in dcraw to output final quality images, no post editing. Dcraw is actually a more amazing application than I originally perceived.
Mind blown again!
Yeah, I'm still fairly noobish when it comes to Linux :o but I am a quick learner. ;)
-no compiler
-PC only has 1gb of ram and a single core 1.6ghz processor ( :eek: )
-they have 90+% of the HDD full so dual boot isn't really an option
-I killed my only USB drive recently (by some unknown means)
Soooo... Basically I'm screwed unless I can find a 32-bit version (or finally get the $$ to get a new HDD for my computer)
Here is the link to the .draw
https://db.tt/K9oe2Ebq
Its nothing spectacular. I just wanted to see if it would work for my device. I took the "exact" same pic with my stock camera so I would be able too compare the results
Thanks for the offer to help. :) hopefully this yields positive results. I would love to be able to use this on my phone :)
-no compiler
I need to rebuild my dcraw, your camera is unknown to my copy.
Did you use FreeDCam? Other?
If other, do you have a link to it, or did you mod the camera yourself?
I don't have access to an SV anymore - what's the spec for the image size?
That's my target exactly.
And I think that last one I did of your puppy pretty much nailed it (I for one am not getting sick of him lol).
Try what I did on your other pics.
Did you synthesize your own -r values?
I'm thinking to do that for mine.
Once we have those down - or figure the best way for each individual to get there - we ought to be off to the races.
I used the onesraw.apk (the one for the one s)
Link:
OneSRaw
The camera is a 5 MP, 2592 х 1944 pixels, autofocus
I just figured since i have the One SV, I would give this version a go. I could try camera2 if you'd like
Ah - yeah, defcomg has added various cameras into dcraw but only publishes the original source and the compiled Windows.
No worries - I had to fix it for mine, I've shot him a note to get me what I need to fix it for yours.
Hey Granite - want to see something dramatic with your puppy?
dcraw -v -m 10 -r 2.132583 1 1.480864 1 -6 -T -H 2 -g 2.7 2.5
First thing tomorrow morning, I'll give these parameters a go. I left my laptop at work, which happens to have my environment for photo editing. :(
What I really need to do is get both computers up and running, then I'll be cooking with butter! :D
Ok, he got me what I asked for - but - that's not really compatible with your camera, I guess.
Taking a (pretty good) guess based on your spec and file sent, I built the first line - but his supports the second line -
Code:
{  6746112,2592,1944, 0, 0, 0, 0, 0,0x61,0,0,"HTC","OneSV" },
{ 10782464,3282,2448, 0, 0, 0, 0, 0,0x61,0,0,"HTC","OneS" },
The first 3 numbers are - raw file size, and x*y size.
So - please see if the other camera will work for you.
