Help razr m wifi troubles
mattp341
My xt907 is showing connected to my WiFi, yet it's not actually pulling any pages up successfully. Can anybody help?
Welcome to Android Forums.
Can other devices successfully use the wifi connection in question? Can you use your M on other wiffi connections?
... Thom
There is a setting in WiFi that won't allow it to connect to weak signals. Turning it off seems to help connectivity. Give it a try and see if that helps. If not, I don't know what to tell you. It seems at first the phone has trouble with Wi Fi and then it gets better for some reason. I rarely have a Wi Fi mine won't connect to anymore.
