slipkn0t2012
Hey Everyone. If You Used My Bloatware Removal Tool, You May Have
Realized The Hidden Menus Were Gone. Sorry About That. I Have Put The
Files For The Menus In A Zip File (Link Below) For Putting Them Back.
Steps : (Assumes You're Rooted, And Have Downloaded Zip)
1) Download And Unzip The File From Link Below
2) Install ES File Explorer From The Market, And Open
3) Press The Menu Button, And Click Settings
4) Scroll Down And Click Root Settings
5) Check First 3 Boxes, Allow Root Privileges
6) If You Downloaded The File On SD Card, Skip To Step 7.
If You Downloaded On Computer, Copy It To Your SD Card
7) Using ES Files Explorer, Navigate To The Unzipped Folder
8) Press Menu Button Click Operations, And Select All
9) Press Menu Button, Click Operations, And Click Copy
10) Press Back Button A Couple Times Until You Just See /
As Your Directory. Navigate To System, Then App
11) Press The Menu Button, Operations, And Paste
12) Go Back To Root Settings (Steps 3-5), And Uncheck Mount
System As Writeable. Then Reboot Phone.
13) You Should Have The Menus Back
https://www.dropbox.com/s/a4sok9w1vczwyxf/HiddenMenus.zip
