Is there some place to download the latest maintenance update so that it can be reapplied to the phone again. Just wondering if this might help with some of my issues. Not sure if this is possible or not. Thanks!
You should probably do a factory reset if you are having a lot of issues. You would have to back up your apps and reinstall them with AppBrain or AppList Backup
