Root Re root after ROM???
Yeah your good.. Now when you run a app that needs superuser rights a pop-up will come up and you just have to click allow.
I just installed DarkSlide. Do I need to "re root"?
If so, I noticed Z4 is gone. What should I use? Thanks
Just so you know, z4Root does not work on GB. Currently there is no way to root GB for the DX, that's why you have to install the pre-rooted version ;)
