Root Read before rooting ZVC
_rabbit
Just a head ups for people wanting to root ZVC with PG's latest Root and Recovery AIO.
THERE IS NO SOUND AFTER ROOTING. There will be no sound from raising or lowering the volume from music, audio apps such as youtube and even calls. Various people have posted about this issue but PG is working on it. Also, putting the phone in vibrate, it won't vibrate.
There is an error installing Clockwork Recovery Mod
If you try to reboot into recovery, you will boot in a bootloop.
To solve this, after rooting, go to the market and download Rom Manager. Pick boot to recovery and it will prompt you to select your phone model which is the LG Esteem. Then it will proceed to install Clockwork Recovery.
IF you made a backup before rooting, boot into Recovery and go to restore to the latest backup you made. This happened to me, so after restoring to my backup, I had my sound back.
umm I've not had any issue with sound or viberate or CWM just running the AIO. My issues were with GSE II n the stock ZVC ROM. ;)
I have ran it more times than I can count. I also fixed all the typos in the scripts early this am. ;)
i was testing this today pg every time i update and root with aio i lost sound to everything even when i down grading i had no sound but it came back when i did a factory reset but when i used the regular root file for zvb sound worked even with the with the first root made for zvc sound worked so just letting u know my findings mite help u
you redl the AIO today? ;)
