Root Read before taking .621 Soak Test
There is now a .621 SBF, may want to update the OP, original leak was on XDA if you wanted to track it there or its also been posted a few places over @Rootz.
not sure if this is gonna help the SBF issue....https://sites.google.com/site/motosbf/droid-x-sbf-files
you can find all SBF files from 2.1 to 4.5.621 here.
*bricked my droid x when I tried to SBF backward...(note to self,"don't do that again")
MEM_MAP Blank
Service req'd
OK to program.
Found the SBF for 4.5.621 and it worked...
I got a new phone (with the replacement plan) after the screen on my original rooted phone went black when I dropped it.
The new phone came with .621 and I'm wondering if I can root it with the instructions applicable to all other GB versions.
Thanks.
No. There's a different method. I'd look up the link for you, but that's not so easy on Tapatalk. Just look in one of the many threads about 621.
Sent from my Transformer Prime TF201 using Tapatalk
My friend has a droid x with system version: 1.2.148.mb870...
I was looking this list of SBF files and am a little confused as to what version I should be looking for. Where I got that number from was under system--> About phone. I think that's what would cororlate to those that were listed by enibudy.
What he is hoping for is a less buggy phone, maybe bettery battery life. I told him he may want to look into ROMing his phone, because it worked so well for me. I think understand that the kernel is on lock, and bootloader is locked also?
The reason I am posting here is because his phone keeps trying to download an update, and he wants to backup his phone first. If it was my Triumph, I would do a nandroid backup and be all good (I'm going to look into that in a moment). I am hoping that someone can show me some shortcuts to the info as to what I need to know to not loose his stuff or brake anything.:captain:
Edit: My bad, he has a Dx2
