Reading/Writing SDHC Cards
poolshark
Tech moron here.
I keep all my MP3 files on the Note's SD card. Is there a better way to read/write on it without removing it? Every time I have to add mp3 files, I have to shut down the phone as the battery must be removed to get to the SD card. Neither have I found a way to read its contents on the phone.
Thanks.
That's what I thought too but I can't seem to find the option to read or write on the card. The PC only reads the internal memory by default.
I'm stumped.
there should be "phone" and "card" if you connect through MTP
or two new directories if you connect using USB connect options in your Note
Before connecting again to the PC, I unmounted and mounted the card. For some reason, it now works.
Thanks for your replies guys.
