TexasBadger
Here is a summary of what I achieved by routing and tweaking my 16-month-old Eris last weekend
The resale value of the Eris is down to about $35, so the risk is minor even if you brick it.![]()
Wow. I haven't seen asks below $100 on CL, and I haven't wanted to waste a bunch of time when the true status of the Eris might be questionable to begin with.people still ask $100+ on craiglist for them,but i dont think they sell for that. i personally have bought 2 of em now for $50 and passed up a couple others for the $50-$75 range.
All I mean is that when you're buying used on CL, there's no warranty; it might not look good on inspection as it is billed; you have to check for clean numbers; etc.
Many of them are perfectly fine, but if I could get a refurb with a warranty for $100-$110, I'd probably lean that direction myself. FWIW.
FWIW if anyone has these in decent shape with clean numbers to sell at $50, I'd certainly be interested.![]()
im keepin my lil buddy,but i can watch CL and pick you one up if i see another for that. if youre willing to pay the shipping on it.
Did u get my emails?
just the ones with the pdf files the other day... and i just got a pm.![]()
They weren't important.![]()
i swear they werent really there. i actually was messing with my lil buddy,and saw them there. i went back to the pc and checked again there they were
I picked up one more phone for $75 locally on Craigslist.
That's the best I've been able to do. Most are asking 100+ and when I offered $75, they told me to bugger off.
If you can buy them on CL for $50 or less (clean), you should ebay them as you can sell them for 80-100 all day long.
I'm calm! I said I liked it...Scotty85:
Calm down, avatars can be as misleading as Craigs List, and shame on you for your eBay deception!
Okay, Scotty, I retract my shame comment. Sorry 'bout that. You didn't state previously that you listed the phone as nonfunctional on eBay.
ebay doesnt count,lol. i sold a broken droid X for $100 that dint power onpeople will buy literally anything on ebay for 5x more than its worth
i never could get the X to work,so i sold it for parts with a full dedcription of its condition and what i had tried to do it fix it. i couldnt beleve someone actually bought it.
guess if you had an x with a broken screen it was worth it... you got an extra battery and other parts with it. no way id ever mis-represent somethin like that.
hey I just rooted my eris for the specific reason of moving my apps to my SD card so I can actually get more than 2 legitimate apps. Can you point me to a forum that will tell me how to do this? Any help is greatly appreciated! Thanks!
I'm using an app call SuperBox that allows me to move apps to the SD card.
does that app partition your sd card,BC?
froyo and gingerbread roms have a feature that let you move apps to the sd card built in.
just go to settings/applications/manage apps then go to each app youd like to move,and it will have an option "move to sd card". you just cannot put widgets and things on your homescreen on the sd card. those must remain in memory.
i believe that the app is moved back into phone memory when you open it,so apps on the sd may take a hair longer to launch if theyre large. if you find this to be the case,you might want to leave apps that you use alot in phone memory
if you want to use a 2.1 based rom(xtrsense) there are some things that you have to do to set it up,wich are described in the developers thread. ive never done this while running a 2.1 rom,so im not familiar with it.
