Recommend a case for Thunderbolt
R
redwingfaninnc
Guest
Can you please recommend a black silicone case for this phone? I bought a crappy one from amazon that bulges on the side.
Thanks.
I'm using a crappy Chinese one from HandHeldItems.com that doesn't bulge. I also had a hard plastic cheap case that worked fine, but was an effort to remove the change batteries.
Each one cost me ~$2.50. Look on Techbargains.com for coupons for 20% off or so to the above website. I got the case and three pack of screen protectors for $5. <shrug> Works for me.</shrug>
This is where I got mine, this seller. I would recommend this. I had a case from here from my blackberry as well. These TPU cases are awesome. Lightweight, cheap and very form fitting.
Not clunky and heavy and cheap feeling like hard plastic.
Not cheap and stretchy like the rubber ones.
These feel like one with the phone. I've dropped my phone a few times, and this pair with a screen protector has been awesome for me.
post3rs | eBay
This is the best "silicone" case you will ever buy. I quoted silicone because this case is a very unique feel to it and isn't your typical silicone case.
Worm, i had to take mine off. didn't you notice it blocks the sensor that shuts the screen off when you bring to your ear? I was hanging up on everyone all of a sudden and found that the strip under the speaker grid thing (above "V" in Verizon) was blocking that sensor.
the reason i'm asking you is i want to know if you noticed that or not.
I loved that case and can't beleive i had to get rid of it
Yea, it slightly blocks my proximity sensor, but it doesn't cause any problems with phone calls.
Does anyone have both the case mate and the ringke cases? I want a silicone case, but the case mate looks amazing! I also don't care about protection, just don't want my phone dented up
