Recommend a screen protector...
Hi.
I'm looking to invest in a good quality screen protector to keep my note in good condition. At the moment I have a cheap one on there and it makes the screen visibility really poor outdoors.
It seems like catch 22. The screen's too good to leave unprotected - but it's also too good to stick something over it that reduces visibility.
Since there are so many protectors to choose from I'm looking for a recommendation. Looking at user reviews the official Samsung protector sounds poor and I'm leaning towards Martin Fields.
If you have a protector that does the job without reducing visibility please post.
Thanks in advanced :-)
I am also looking for a good screen protector. I have now the "Muvit" screen protector but this one is very dull and I loose all the resolution of the screen. Any suggestions ?
The last phone I used a screen protector on was my Sony Ericsson P900 because it had a plastic screen. I've never seen the point of them when the phone has a glass screen. Having said that I know some people use them solely in case they drop the phone in the hope that they'll help protect the screen and not actually to prevent scratches. Each to his own I suppose.
EndOfLevelBoss, I can vouch for Martin Fields protectors. A friend of mine had them on everything and he said they didn't reduce visibility or usability (on an iPad, iPhone and an iPod Touch).
I use screen protectors solely to reduce glare. So I bought an antiglare one. Forgot the name. I got it installed on the phone by the store.
I definitely recommend the SGP Glas.t. It'll cost you $40, but it's worth the cost and by far the best screen protector i've ever had.
SPIGEN SGP Samsung Galaxy Note Screen Protector GLAS.t Premium Tempered Glass Series - GALAXY NOTE [INTERNATIONAL] - GALAXY NOTE - Samsung - Cell Phones
I will echo this. I started out with a SGP Ultra Crystal screen protector which was good but difficult to install and easy to scuff up. The Glas.T was SUPER easy to install and has amazing clarity. I think it is superior to the Note's glass screen because of the oleophobic anti-fingerprint coating. Works great with the S-Pen as well.
I may well go for this when my protector needs replacing. Looks awesome even if it is very expensive.
