wow im dumb...i read somewhere that if i try to install villian i ruin my phone...does that mean i have to buy a new phone now?
yes i have a sprint hero. i flashed it with flashrec-1.1.3-20091107-2, recovery-RA-heroc-v1.6.2 and used VillainROM5.4. i had done a nandroid backup before and have that saved.
I don't know if this will work, but if you have adb installed (if not refer to the sticky/guide at top of this forum) you could try and get it to boot into recovery via adb.
i ruu'd again and did the kitchen setup. i got to where u have to do a nandroid back up but when i try to go to recovery mode it freezes on the htc screen. and i cant get any further than that.
)And it's because of problems such as this that I tell people to root manually. It always seems that the people that use the kitchen to root are the ones with the problems, and they don't know how to use adb to fix them (most of the time).
If when you RUU'd and rebooted, you could use your phone just like it was out of the box, then you're certainly not bricked and shouldn't have any problem re-rooting (preferably using the manual root method)
