I have had my MT for over 10 months now. I have flashed and tried almost all the Roms out there. The past month, I had reverted to the nandroid backup of the stock VM rom, rooted with gingerbreak. I wanted to try out the latest update to the Minimal Triumph rom. As per my normal practise, I booted into CWM and made a nandroid of my stock Rom.
While doing the backup, I got a message saying that there was an error while backing up data. I rebooted the phone at this point and after the splash screen,I got a blank backlit screen with two vertical lines. I let it sit a while and it then booted normally into the stock rom. I then rebooted back into cwm. I again got the blank screen, but was able to get cwm after a while . I did factory reset and flashed the Minimal Triumph rom.
Again,I got a blank screen after the initial boot, but booted up into the rom. I set up the rom . I was getting a blank blue screen when trying to watch HD videos in YouTube. I thought a reboot might help, so I rebooted the phone. Now, the phone takes at least 10 minutes to get to the lock screen. And is unresponsive for another 10 minutes. When it finally responds, as soon as I slide the screen unlock icon, it reboots and the cycle repeats. I now managed to get into CWM, but the capacitive buttons to select the options don't work. The power and volume buttons work fine.
Would appreciate any help on this.
