What if my phone won't boot? How do I get into recovery without the app?
When the hijacker runs, it will automatically create the "/data/.recovery_mode" file after it finishes. This tells the system that the next time it boots, it should boot into recovery. But, when the system starts, the Droid X Recovery Bootstrap will then delete that file when Android is fully started, to prevent you from booting into recovery. So what does this mean? If you fail to boot, simply pull your battery, and your next boot will be into recovery (unless your /system is *really* hosed, in which case you need to SBF).
From Koush's site..
