[Recovery]ClockworkMod 6.0.3.7 recovery for Ring
It has been working for me so far, but I have only booted into it once. The yellow triangle that appears during the normal boot has me puzzled, though. I'm not sure if I should be worried about it or not, however part of me does think that it may be normal and that it is just Android's way of saying that it has been modified and that it really isn't something to worry about. This is the first phone I've ever done this with, by the way. I flashed with Odin.
thats exactly what the yellow triangle is. thank goodness this isnt a locked bootloader or else the phone wouldnt boot past that horrid triangle :P
Tried to flash in Odin twice in recovery. Odin says Pass and is green however it'll reboot a short time later. Then when it reboots I see a yellow triangle with exclamation. If it was successful how do I get to CW mods menu? I reboot in recovery and it's the same default menu.
Also what apps, if any, do I need. Maybe that's what I'm missing. I didn't have busybox or anything.
Can someone give me step by step instructions. I went to the video but it's a little different because of the Ring.
NEVERMIND SOLVED DELETE THE RECOVERY FILE!
i have boost ring and i accidentally pressed the wrong button in odin and now it stuck in boot loop and ive tried everythin but flash a pit file because i cant find one any where does some one have alink to the pit file please and thank you
I literally just flashed this recovery, once got my nerve up (never used ODIN before) everything went smoothly.
My question: When I boot to recovery, is it normal for a yellow triangle to appear, then the recovery starts?
I've booted to recovery 3 times now and the yellow triangle flashes on the screen every time.
My second question: Is this recovery capable of formatting/partitioning the ext sd card?
TIA...
Ok so i downloaded the tar file, Ran it through odin & all went well or so i thought, this recovery cannot format ? If this be the case is anybody working on this issue ? My god damn wife's phone is now on the fritz & i just wanna fix it so she'll shut up about it. Phone just sits on the boot sreen gets passed the boot logo though. Any help here would be great.
I just got the Ring this afternoon, and I'm a Mac user. So I'll thought I'd just pass this along since people are having issues putting CWM on this device.
So if you haven't already, install ADB.
After you do that, install the frameroot APK with a "adb install whateverapk.apk" and go through the rooting process.
Install yourself a copy of https://play.google.com/store/apps/details?id=com.cgollner.flashify&hl=en the same way you did the frameroot APK (use another device :p).
Take the CWM_Prevail2_Ring_Koumajutsu.tar file and unzip it. It'll give you a plain-o recovery.img.
You can flash that using the Flashify app, then do a "adb reboot recovery", then bam, there's your ClockworkMod Recovery all nice and pretty.
