That is not going to work. If the stock recovery was capable of flashing zips not signed by ZTE we would have had root 3 months ago.If someone makes a flashable zip of the twrp i can sideload it and see if it flashes. I tried sideloading the img and get a error code.
I've had a ZMax Pro for a little over a month. And I need to use this phone as a USB tether via my home WiFi. My old S3 did it fine with Easy Tether Pro. I do not want to use my data, but my wireless router at home and plug it into my PC and use my phone as an adapter type via USB. Are there any apps to do this? I've tried a few and failed. If this phone could root that wouldn't be a problem...
There isn't really any advantage to using ftm mode. All it is good for is adb shell and as far as I know it doesn't give you any additional privileges that can't be gotten while booted into android normally.Has anybody thought about the ftm mode
There isn't really any advantage to using from mode. All it is good for is adb shell and as far as I know it doesn't give you any additional privileges that can't be gotten while booted into android normally.
It won't have security info, just disables RO to RW. Try this:Fastboot still disabled. ADB Sideload may work if you try to push the new recovery that way. But again, no idea if it will work. ** The command didn't work. Upon reboot the ZTE splashscreen doesn't have any text talking about security.
so i made some tests today on a member's phone , this is our way to test with
http://forum.xda-developers.com/axon-7/development/wip-axon-7-root-bootloader-unlokced-t3441204
edl mode is a replacement for fastboot mode on qcom phones , everytime i tried to dump the boot/recovery images or to flash the recovery using the method in the above thread i got [image load failed error status 1/9] i need all to test the above method and report the results here
notice: delete the axon 7 boot/recovery images and replace it by my twrp recovery.img before testing , good luck
Doesn't work here. "Image load failed with status: 1" when trying to flash it.
The Zmax Pro is still a fantastic device for the price and I for one, am still 110%. happy with it.. for those that have not tried it.. just set Window, Transition and Animator to .5 and use Nova Prime setting it's animation to "Faster Than Light".. it will hold you until the root vault is cracked..
??? Any help with tethering undetected?Maybe It's Time To Step Back For A Day Or Two..
I'm sure by years end a delivery system for TWRP will manifest itself.. the lock will get broken..The Zmax Pro is still a fantastic device for the price and I for one, am still 110%. happy with it.. for those that have not tried it.. just set Window, Transition and Animator to .5 and use Nova Prime setting it's animation to "Faster Than Light".. it will hold you until the root vault is cracked..
What does this have to do with twrp... or even recovery??? common guys.??? Any help with tethering undetected?
Your awesomeNotice : sorry but don't get so excited as we still don't have a method to flash it but we are working hard to find one at the below thread , we are currently at about 60 percent to obtain root on this device
http://androidforums.com/threads/zte-zmax-pro-z981-root-discussion.1055354/
Also I'm not responsible for any bricked devices.
Warning: you must enable oem unlock in the developer options before trying to flash or test the recovery.
Download :
#Beta 1
http://www.mediafire.com/file/p4x10tb46jfcijq/twrp+v3+for+zte+zmax+pro+beta+1.zip
this recovery was compiled using latest zte z981 source , u can find it here [all compile errors were fixed]
https://github.com/messi2050/android_kernel_zte_urd
The device twrp folder:
https://github.com/messi2050/android_device_zte_urd
If you like my work please donate to minoforever216@gmail.com [paypal]
thx bro , we already on our way to get a development device it's being shipped now.I'm excited about this and i'm totally donating my zte max pro for development. i'm pretty tech savy and I do have linux and windows os so please contact me. Skype-lxf5856
