G
Just flashed this myself, and now I'm flashing the Astro theme. Loved 1.7.1 and the only reason I'm going to 1.8 is with the hopes that MMS works without me having to manually enable the 3G connection. Excited to get this back up and running!
Are you still theming Nameless or one of the others?
Silly question but where are these themes like Astro to check out. I didn;t see them here.
I know the Blued theme is right in the xda post with the rom though.
This ROM is rockin'...great battery time, smooth operation. I'm happy![]()
Just installed this rom from uncommon sense and just curious if i can get some help getting a couple things accomplished...
1. Looking for transparent notification bar with hidden location icon
2. Install music mod music player
3. Looking to get vanilla lock screen
4. Looking for maybe a rosie launcher...not the default launcher and want to keep the sense widgets.
Any help would be greatly appreciated.
Is the Perflock already disabled on this ROM already? Tried to disable it with SetCPU but got an error. Since it's using the new kernel i'm wondering if it's already disabled or does the Dev have to update setcpu to work with this new kernel.
Also, great ROM, just had problems with Handcent. Was not listing the texts in the threads screen at all. Fresh installed Hancent as well and got the texts but was not displaying any of them. Back to stock. Bummer.... Will try 1.9 and see if it works out.
I liked the stock sms app so much with this ROM that I ditched handcent after using it for 8 months so I don't know what to say about your issue other than this is the first I've heard of it.
Totally agree re kernel. I'm almost about to delete setcpu entirely because of this. I wonder how it works with SR but I haven't flashed anything other than SP2 and then immediately went back to this rom.....
I've used just about every kernel out there and I've used setcpu quite extensively, but I have found with this new kernel setcpu is not needed imo. The battery life is fantastic and the smoothness perfection.
