Root Redux CPU Clock Speed Issue
What do you mean exactly?
Code:
mPowersaveFreq = "729600";
Sorry, I mean if mPowersave is set, or screen state scaling is set, then when the screenis turned off, the set max frequency is the same as the set min frequency.
mPowersaveFreq is the max frequency when the screen is switched on. It seems to override the user set max frequency - which might be obvious based on the UI (user frequency settings may be disabled), I can't remember.
