Hi. If anyone has issue with rejecting incoming or "SIM from unknown source" popup here's an app to fix these.
https://drive.google.com/file/d/0Bw4z78Q7Eys6cVJ2bDZRS3ZDcEk/edit?usp=sharing
C811ExtraSettings.apk
If you installed my previous "C811 Call Blocking" app please uninstall it.
Install this as a normal app.
There are two switches.
When "Enable non-Verizon SIM" is set, it does not block calls so the "Receive incoming calls" setting gets "On" and disabled.
I discovered the popup setting thanks to this thread.
