Fabolous
Superuser
A lot of people have been asking for a method to remove themes. Well, this file will work with any theme. It removes all themed apps (restores the stock versions), as well as removes any custom fonts and themed frameworks.
This should also help those who have removed stocks apps restore all of their stock apps in the case they want to do the OTA update to Froyo.
Requirements
-Rooted
-Have Droid X Recovery App
Instructions
-Download the following file: MEGAUPLOAD - The leading online storage and file delivery service
-Place it on the root of your sd card
-Launch Droid X Bootstrapper, bootstrap recovery, reboot recovery
-Navigate to 'install zip from sdcard'
-'Choose zip from sdcard'
-Find 'Fabolous_theme_killer.zip' and select it
-Press 'Yes'
-Reboot
You'll have to remove bloatware again, if you did so.
To Remove just custom fonts and return to stock fonts
DX_stock_fonts.zip
Requirements
-Rooted
Instructions
-Press 'Yes'
-Reboot
DX_stock_fonts.zip
