K keeylyme Lurker Oct 27, 2010 #1 How do you remove a single bookmark? if i hold my finger on the bookmark to drag it the entire screen of bookmarks comes along for the ride.
H HTCRALEIGHFAN Well-Known Member Oct 27, 2010 #2 open up your internet app (the 1 that comes with the evo) press menu then bookmarks and press menu again and pick delete and select what you wanna delete
Mr. Ed Extreme Android User Oct 28, 2010 #3 like he said internet.menu.bookmarks.long press the bookmark you want to delete.select delete or apps.bookmarks.long press bookmark.select delete either will remove it from your bookmarks and bookmark widget
