Root removed gtalkservice.apk on and get force close
Swanky
so i rooted the phone and was going through and deleting programs that came with the phone that i didnt need.. myspace.. dualclockwidget.. the things i dont use.. well i deleted gtalkservice.apk thinking it was the actual google talk app and now i get a force close whenever i turn the phone on.
"Sorry! The process com.google.process.gapps has stopped unexpectedly. Please try again."
i've followed some of the steps from other forums such as:
com.google.process.gapps force close !? - xda-developers
but this is for the XPERIA X10 so i didnt completely go through with changing "chmod ####" since i figured the numbers and file structure might be different based on the phone. now i have tried replacing both the gtalkservice.apk and Talk.apk by placing on the sd card and copying into system/app.. i've even gone through cmd and did a force install to the phone of both .apk files but after that im not 100% on what to do..
i dont want to have to restore the phone and lose all my customizations and apps (even though i've backed up).. unless i absolutely have to.
any help would be appreciated, and thanks in advance :)
The only thing I can think of (and mind you, I know nothing about rooting) is if you can find someone who has rooted their phone and ask them to send you that .apk file. Then maybe you could reinstall it. Not even sure you can reinstall things like that, but it's the only suggetion I can think of.
i have all the .apk files i need.. i found a 1.6 backup from another forum site that has the talk.apk and gtalkservice.apk. i just need to know exactly how to place in the system/app folder and what chmod #### is because i know its not the same as other phones.. that would be all too simple if it was haha. i've already tried doing a copy to the phone, a push install doing "adb install path/filename" in cmd prompt thru windows which actually did the install but didnt fix the problem. i've even placed both apks on the sdcard and tried to do a copy that way but i'm still a little uncertain on the proper way to do it that way.
so i caved and did a reset thru settings>privacy on the phone.. it wouldnt even let me setup the phone so i had to do a factory reset.. still getting the force close when the phone is turned on. also, i can't download anything from the market. please please, someone help..
if i could get someone's gtalkservice.odex pleeeaaassseeee let me know.. i tried to use the phone today when i was in service range and i can't make phone calls, i can't use the internet, i dont receive texts and i cant send them.. i have the gtalkservice.apk, but i don't have the odex.. any help would be greatly appreciated so i dont have to buy a new phone or waste money on an insurance replacement..
do a google search for "lg ally system dump" ... you'll see
LG Droid Ally Dump - xda-developers
Follow links there to download the proper complete backup of the folders and files you will need to restore your Ally.
I downloaded those files a while back (but not on this computer, so it's not easy for me to get them now, but I could send them to you Monday if you still need) ... but I have ssh access to where they're stored and did a directory search filtered for "gtalkservice" and found:
Ally/LG Droid Ally System Dump/app/gtalkservice.apk
Ally/LG Droid Ally System Dump/framework/com.google.android.gtalkservice.jar
Ally/LG Droid Ally System Dump/framework/com.google.android.gtalkservice.odex
haha i actually found that same dump a few days ago and downloaded it.. now i just gotta get the restore down..
any insight on how to do a proper restore? i dont mind unrooting if i have to..
i dont have nandroid though because my dumbass cant follow directions and didnt pay attention to backup the phone properly.. just the .apks i was deleting.. not even the .odex files..
well you could hook it up to your pc and update the phones software to v9 i know that unroots it not entirely sure if that would fix anything.
i did a full system dump on my phone any certain files you need?
so i did the software update to version 9.. didnt even realize that there was an update out.. i was on v6..
so far no force close at startup.. and im able to download from the market again :D.. i hope this worked for sure..
thanks mate :D dont know why i didnt think of software update or searching for it before..
no problem swanky. just keep in mind as of right now the the root hack is broken in the Ally's v9 software.
how do i restore the phone with the dump file?? I rooted the phone and now the market hangs. There was another post the had instructions to get the google talk app back, but it did not work. Please Help!!
first make sure that you've updated to v9.. it will remove the root but will fix the market problem.. it did for me. from doing a factory restore on the phone and update of software I actually unprovisioned my phone from my account haha.. I had to manually reprogram the phone (called verizon for help and they gladly helped me reprogram it, i just told them i updated the software and did a hard reset). as far as doing a restore, i never got a clear answer on exactly how to :eek:.
good luck.
