removing vanilla lock screen
Ive done some searching and came up empty. I want to remove vanilla lock screen and re installing the htcsense lockscreen. I tried just flashing a custom htcsense lock screen but that didnt work. I cant even figure out where vanilla lock screen is installed:confused:. Any idea's?
First off, which ROM are you on, and how did you go about getting the vanilla lockscreen to begin with?
Im using the cyanogen froyo beta so it already came installed on there. Im kinda thinking that the Htc sense lock screen may not even work on it but i would like to find out where the vanilla lock screen is installed so i can customize it.
not sure where it's located, but the HTC SenseUI lock isn't going to work as Froyo is an ASOP ROM.
that's all a matter of opinion.. some people prefer SenseUI over Vanilla... I'm one of them :D but I can get along with Vanilla as well.. just miss my SenseUI widgets in Froyo..
i prefer the vanilla lockscreen but i like sense after i unlock.
im running nfinite45x's stock .6 rom with v4 710 oc kernel. is there any way possible to achieve the vanilla lockscreen?? thank you
I know there is a zip on the page for fresh 2.1.2 to remove the htc lockscreen, flashing that over fresh did but I don't know if that works for other roms or not.
