Root [Req] Navigation bar in CM9?
Ken2Chill
I've tried some of the flashable zips I found online, rebooted but nothing happens. Is there method specific to this from or is it impossible?
Those are instructions to flash cm9 , I need to know if there's a way to get a customizable navigation bar
lol, why don't you have a navigation bar on your phone? If your running one of the ROM's from here, you should have a nav bar.
I'm assuming hes talking about the bar up top you slide down to view notifications. When I first flashed cm9 i didnt have that bar, until after i flashed gapps.
The navigation bar is the bar on the bottom of the screen that has home, back, menu search on other phones. I know we have hardware buttons but they were nice in Akop, its just that CM9 is more stable.
Those are stock, is there any way I can get the customizable one? The one that adds the "Navigation" in settings\system maybe?
