The~Skater~187
Android Expert
Does anyone have the stock touchwiz framework & .jar files for GB?
If so could you send them to me, please? Thanks in advance.
If so could you send them to me, please? Thanks in advance.![]()
May i ask what are you planing to do with them?
Trying to get touchwiz 3'0 launcher from the galaxy S2 to work on our phones. Partially there already
I posted a working version of touchwiz back in August
http://androidforums.com/galaxy-prevail-all-things-root/400628-touchwiz-launcher-3-0-a.html
it worked fine on froyo anyway
For this launcher to work, do the twframework-res.apk and the twframework.jar have to be installed or will it work just like a normal app? I currently have the twframework-res.apk and the twframework.jar installed, I just want to make sure that if I remove them it will not screw things up.
I dunno. like I said, its been a long time since I've messed with it.
I just tested it without the framework and jar. It's working great!
Thanks Blood. If I can get some of the other things I stole off my boys S2 working with this, would you mind if I through it into my Rom for those that preffer the touchwiz?
That's why I was working on porting Touchwiz 3.0.
What about a systemUI.apk from touch wiz?
Touchwiz does not have a system UI. Atleast not that I have found.
If i am wrong someone please correct me.
Well is it framework that has the lock screen and status bar?
Actually I think in UOT it as for the touchwiz stuff but I don't remember if it asked for a system UI from touch wiz
UOT only uses framework-res.apk & systemUI.apk.
I had to check myself, lol.
No, I was trying to port touchwiz 3.0 from my buddies Galaxy S2 and I thought I would need the framework and all that to get it to work. But blood already ported it a long time ago.
What does the status bar and stuff look like?
Is it like stock GB?
Download Bloods TW port and try it out.
I did lol i still have the WP7 status bar theme.
I don't think Touchwiz will change that. I think you'd have to mod your systemUI to go with it.
