Root [Request] Gingerblur Bar
PACAnesFan
I've tried to make one and I tried searching for one and failed on both counts. Does anyone have or could make a dock background that is the Gingerblur blue and is the size of the stock Gingerbread dock background?
Thanks in advance.
Thanks in advance.
you're looking for a dock background? or the notification bar?...and which blue?...there are multiple shades of blue throughout GingerBlur...
I have attached the dock background I tried to fix. This is the full size dock background that would for 5 dock icons. I would like one for the center 3 (like the Nexus S).
What I am doing is using Go Launcher and using it's white icons to make a Nexus S looking homescreen, except Gingerblur blue and white.
Yes. That is what I am looking for. An AOSP dock in blue.
well lets see...here is a AOSP Gingerbread dock...
here here is one i made Blue just real quick...
now they look completely different with something behind them because they are slightly transparent...
i can mess with the blue one however you want....more or less transparency...darker or lighter...you name it...
I should be able to take it from here. I was having trouble getting the bar down to the 3 icon size with the rest of the dock transparent.
Thanks for the help.
