Root [REQUEST] How to build a fresh ROM for Micromax A75??
Status
Not open for further replies.
aayushdutta
Hello All,
This thread is dedicated to all the Senior Members of this forum and the Developers.
My question is that, I have tested all the ROM's currently compiled by Ninad for the Micromax A75. They are up to the mark and are very good, thanks to Ninad for doing us the favor. I just wanted to ask, Can't we just make a new fresh ROM for the device by modifying and editing current STOCK ROM of the device??
In short, this question is asked to Ninad that how exactly he is compiling and building up those ROMS (Eg. UB-A75-1 & UB-A75-2)... Can he or any of you who knows HOW, post up a step-by-step tutorial thread of compiling a ROM for Micromax A75?
Guys, if many of us know what exactly needs to be done to make a ROM maybe one of us trying could find out a solution to one of the problem faced by us today in compiling and installing ICS or MIUI into this cellphone.
I have almost all the tools needed and can also download new ones if told to do so. It is a humble request to Ninad and other members to put up a tutorial reply or just explain the steps. I really want to help you all....
Thanks in advance.
I think that method will be outdated shortly as soon as Recovery gets stable.
So if you give me log of the recovery then I can check the problem and attempt to fix buggyness
Check the All-Things-Root
As soon as recovery will be stable you can create a flashable ROM with your modifications and flash it simply
Well, yes... you are correct. But I actually need the method he (Ninad) used to make that UB-A75-1 ROM. And then, make it flashable onto the device.
You know, the old fashioned way... :)
@varun if I do something in that cwm the phone will hard brick? coz kumar said something happenedto his a75
his mobile recovered?
Hmmm....unsure
But you have already tried that as per your statement here and you solved it too
@kumar just reflash all the original files or just system.img and recovery.img
I also did something in cwm and my phone got bricked
even charging icon doesn't appear after plugin in the charger but reflashing solved the problem
So it shouldn't create any problem
Please reply on my thread
I don't know how he did it but I will share what I know.I am also going to give it try but don't have time today.
You need two tools which should be used under linux.
1. unyaffs
2. mkfs.yaffs.x86
Add their path to system.(in bashrc)
Use unyaffs tool to extraxt system.img
Code:
unyaffs /home/user/workingfolder/system.img
This will extract contents of system.img in workingfolder,keep in mind that system.img will also be there so u remove it before u apply mkfs.ysffs2 command.
Now,do your changes n then apply mkfs command to make new system.img
Code:
mkfs.yaffs2.x86 /home/user/workingfolder /home/user/workingfolder/system.img
This will create new system.img which can be used to flash.
One thing I suspect is,this will come up with wifi issue may..(happened to me with my A70 when followed similar process on stock backup)
The method is not tested yet by me.I will test tomorrow.
EDIT:
It's tested now.It works though I had to compile unyaffs myself.pre-compiled one didn't work for me.
1. unyaffs
2. mkfs.yaffs.x86
Code:
Code:
@mastermind1024 Thank you sooo much for the quickest reply with the actual content which i want. I have extracted the files of the system.img with unyaffs and now have everything.... I tried to change the default launcher inside the ROM by deleting the Launcher2.APK and replacing it with an ICS Launcher from Syndicate Apps renamed to Launcher2.APK to just test whether my built ROM would flash or not.
Then i compiled it back with mkfs.yaffs2.x86, yes i was successful in flashing it. But the launcher didn't launch up though.
I just experienced a status bar with signals, dropdown and options. Below it, everything was BLACK! I know it's the launcher which didn't launch up.
Do i need to change any other setting too with replacing the Launcher APK in system/app???
Guys plz understand Android :o
It would never be so ever (at-least in case of A75)
and at-least as per my knowledge goes ....
Do you remember, the root method we have now, was generated after tremendous trials and errors, ppl here tried many many images and finally one came on being !!
every time the phone did not boot up ...
ever curious how was i guaranteed this won't ever spoil ur device ???
the thing is,
this is the way It was done !
Just that , It won't boot up for some obvious reasons !
It took me so many trials to actually learn how this is done though it was to learn how it is done for android and not how it is done for a PC ! ....
This point of time, I am on a full-fledged way of studies !
Me and Varun are always in talk... grave ness of unto what limit i have restrained android development for it :)
if you decide to make a ROM ,
Do send me the update package,
I will send back the images !! this is what we can do ....
I have indeed scheduled the tutorial for the same as it is no where on the Net !, Will write it When ever i get time ! my exams get over on the 12 of May
Till that point of time, Its a challenge :)
P.S. : Also note that as my methods are no where found on the internet , It is fine as per the Rules of the Forums and all the licenses, I can sure keep my techniques closed source :)
It is competly fine and I am not breaking ANY rules for the same :)
Just to Note btw ...
I have no idea as of now.
@ninad-
I flashed ur UB-1 today,the thing is even I add any app in /system/app, it won't show up on reboot...what is the reason for that.never faced it on A70.
N u can keep ur method closed source but just keep this in mind that if mmx n a75 user kumar had not share stock files then will u be able to develop rom?softwares/firmwares related to linux should be kept kept open source.knowledge increases with sharing.decision is urs,no offence.
@ninadchaudhari
:) Thanks for noticing this thread and replying Ninad. Quoting the above, I am also not breaking rules by forcing you to publicize your techniques and methods of doing a JOB.
It's just that i require you to tell me what all tools you are using (which are ofcource open source) to make the images. If it is yaffs (both) and the trial and error, OKAY. If those are some other, i hope you wouldn't mind sharing them with us... :)
All the very best for your exams though. Do consider this thread as an appeal for a tutorial, not a force or pressure.
TC. :hello:
This is the same reason why I started this thread asking Ninad to tell me what else would have to be changed. That is why I need a tutorial.
I have been developing ROM's for the HTC, Samsung and Nexus since past 2 years (although I never released them), and have never faced up this kinda trouble with any of them. This is one ROM troubling me, but I want to custom it.
Let's hope for the best and also wait for Ninad.
lol guys :D
I never mentioned that i do not want to release it ...
it is just that , I made it a point that even hiding is not a issue ;)
I am PLANNING going to release the stuff after my Exams :)
regarding force ,We all are friends :) Any forcing and pulling is bound to happen and always welcome ;)
@everyone,
as i said earlier, Do send me your ROMS ... in flash able zips .... i can sure convert and Give you back that in image format ...
Still I cannot understand why this method is needed now
Sure if the demand here is for Information sake then OK
But recovery can do what SP Flash cannot do
Well, anything u want, setting permissions, deleting a specific file anything........
And yeah recovery is on the edge of getting bugfree :)
@master mind & aayushdutta After creating system.img u cant flash it :p i tried more times and it doesn't boot up i got triangle android error image.
i already asked ninad to provide tutorial about this he told after finishing this exams.:)
and i extracted boot.img too :D
@EVERYONE
Thank you all guys for your valuable comments, and promises for help... :p
I am here to just make a step forward and giving a bone-breaking answer to Micromax for not releasing the kernel source codes. We need to show them the power of US not the power of ME guys! :)
We when working together would achieve a brand new custom modded ROM with excellent features to make this phone work up to it's limits (it's really getting underestimated right now)...
@androidn3wbi3
I appreciate that you told us what you experienced, but if I tell you mine. I actually somehow made a system.img which got successfully flashed into the phone with the other files such as boot.img and ramdisk which were of the UB-A75-1 setup. Just, the launcher which i replaced didn't load up though status bar did and thus resulted in a failed ROM. Me either extracted the boot.img from the device... :) :)
Hoping for more replies from you guys and continuing this thread.
Wooohhhoo...if it didn't work for u doesn't mean its not working...or may be I am lucky...lol..
I just created system.img with changes in apps,added some apps,removed some,changes in build.prop etc...flashed nicely n booted nicely...
All new apps are showed up n working fine....wifi,bluetooth all works fine...
Only thing doesn't work properly is root.I need to work on that now.
Thanks for your concern though.
N if u can share how u created system.img then may be I can help u get it working too..
Hmmm....unsure
My phone is currently in service center. They tried reflashing several times but a75 didnt boot up and finally they came to conclusion that there is a hardware problem...
@master mind to get root download SU Copy the binaries to bin and xbin folder so u can get rooted already ninad said :) check old post closed root method So ya can get rooted :)
If this was wrong please seniors correct it :)
Now my mobile is in service center i got touch problems. i am :captain: waiting for my mobile :mad:
@varun try this recovery.img Got from Indonesian Forum mt6575 devices :idea:
Status
