Is it possible to get the "Track Skip on Volume Press" feature available on Froyo such as the Sharp ROM? Similar to the CM7 feature when the screen is off and you may hold the volume buttons to skip to the next song. Thanks![]()
I was wondering the same thing but for MIUI gingerbread.
Try going to the Settings>System Tab>Button Settings
and under the Media Button option choose whichever Music Player you are currently using. It works for me in the 1.11.25 MIUI build.
Just did that but only gives an option to wake the device instead of skipping tracks. Weird that PowerAmp doesn't give that option when PlayerPro does, unless I just can't find it.
