imfm
I think it would be helpful to compile whatever information/resources we can find on enabling overclocking. I finally found something that looks promising, so I will start it off.
How to overclock OMAP devices
This post notes that there some files which appear to directly dictate max cpu speeds. Specifically these are:
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq
Of course, these are both currently set at 1000000 on our phones. I tried to alter these in root explorer, but the changes do not save. I also tried in a terminal using the following commands:
sudo echo 600000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
-error: sudo not found
-error: cannot create /sys/.../scaling_max_freq: directory nonexistent
It is my understanding that changing the clock speed would also require changing the voltage. Luckily, compatible voltages have already been found on the Optimus Black:
https://docs.google.com/spreadsheet...DMxVUlNcGhkNmJocDhOZFdYaDNQTEE&hl=en_US#gid=0
Unless someone knows of a clever workaround, I think we will have to alter the kernel source and then compile it. And, unless I'm missing something, the process should be to change the CPU frequency values in those files and find where the voltage settings are stored, then recompile and flash the new kernel like so (although these instructions are for the motodroid so there will be some differences in the process):
How to compile your own kernel.
Any thoughts? Anyone find anything else that might be useful?
Also, has anyone found anything that might help us figure out what the deal is the USB plug-in performance boost?
