Root Resident Evil boot animation
very nice....sound starts a little early. mines comes on when when the boost logo animation plays. is there any way to delay it a little longer? maybe record and start sound after a delay. i tried to take off the boost animation but even though i deleted it still plays it. weird cause ive done it before with no problem.
edit: never mind i just checked and I deleted the wrong file. deleted samsungani.qmg hoping it would help sync the sound and animation but sound still starts too early.....
I Updated the Sound so it syncs better now. Also it's CWM flashable now to make for easy install
thanks man..... imma try it out right now
edit: well u made it an update zip so it was faster installing and you got the sound synced. great job zexnu. and thanks again
Can't get to work black screen
hmm i tested the link again just now and re flashed and its working ok here. just in case here is the link for just the bootanimation.zip and the PowerOn_standard.snd file, to replace the sound file go into system then to /etc then rename stock poweron and save to sd card then replace it with the new file. Also Ive noticed that some time when replacing the sound file the os adds .wav after .snd if you see this just remove the .wav and your good to go. hope this helps http://dl.dropbox.com/u/43480117/ResidentEvilBootAnimation.zip
:DAwesome, glad you liked it. to be honest i didn't think anyone would lol
i am new to modding a android used to doing modz to x360 and have failed if anybody can help me install this resident evil boot screen i have teamviewer and am tired of failing a video would be great
Yeah this boot animation and poweron sound file go very well together. I've been using it since release. Thanks Zexnu
I've been having an issue with the sound. It works fine the first few times I I rebooted my phone, then yesterday it all of a sudden just stopped. I thought I may have muted my phone, so I checked that and rebooted, and still nothing. Any thoughts? I love this boot animation, and would love to get the sound working on it again.
The same thing happened to me, and I was going nuts trying to figure it out.
Turns out, i had my phone set to vibrate-no sound. Once i enabled the sound everything went back to normal.
This bootani worked like 3 times then went in to a bootloop:eek:. I removed it and haven't had any problems since . :cool:
Tried to re flash and got the same results. Used root explorer to manually replace the sound file and still nothing. I must have muted a setting somewhere that I can't seem to find now.
