Root [RESOLVED] Rooted and I have SuperUser, but I'm not rooted?
BillCosby
I attempted to root my phone today. After rebooting I checked and I had the SuperUser icon. I tried downloading Titanium Backup but it says it couldn't gain root access. When I try updating SuperUser it fails. I downloaded Root Checker and it says I'm not rooted. What could have gone wrong?
Hi Bill, I moved it to the All Things Root forum for you.
Have you tried flashing Superuser again? I have the Tmo GS2 SGH-T989, not the Skyrocket, but sometimes when rooting, even though I have superuser in the apps, I'll have to flash it one more time to get root working.
I went into Clockwork Recovery mod and installed SuperUser again and it said successful. After rebooting however I tried using Titanium Backup and it gave me the same message as before. Root Checker says I do not have proper root access. I'll just have to flash the stock rom to unroot.
Since flashing superuser isn't exactly working, next idea would be is to flash a stock or custom rom to gain root access.
DS
That superuser should work. I'm not sure what the problem is. Try downloading it again from here and re-flashing. You will usually get an installation aborted message several times before it works.
DUDE IT WORKED! :D I think what I originally did wrong was extracting the SuperUser zip file. I extracted it and placed it in the SDcard/Download section. Today I deleted it and downloaded the zip file again and placed it under SDcard without unzipping. I went into clockwork mod recovery and installed from there and it failed the first time but worked the second time! I was hoping I wouldn't have to install the stock rom. Thanks!
