mike_s_price
Pending Deletion
I have a Samsung Galaxy S2 and I am finding it particuarily slow. In particular it is when using the Back or Home button. For example, when I exit the email program (via either of the buttons mentioned above) the phone takes up to 5 seconds to return to the home screen. Often for 3 of those seconds the application remains displayed, then the screen goes blank and then the home screen appears. I have most animations, etc. turned off to maximise battery life so I'm not quite sure why it takes so long.
It is very frustrating as it is quicker to dial a number of the phone on my desk rather than wait for the phone to respond to find a contact and call them that way. These things are supposed to reduce our workloads and make technology simpler to use, etc. but this is not the case for me.
Any suggestions? I have turned on USB debugging so when I get home I can see if I can download any loags which may report failure events which could be causing this. I've got the latest firmware running on the device too.
Cheers,
Mike
Cheers,
Mike
