Root Reverse tethering of rooted phones
The site is XDA :)
Its the largest resource for development for WM & Android all over internet !!!
Thanks for highlighting the article though,
Its damn good :)
Is this work but when i install drivers there comes error like it's damaged or not for win 7 32 bit
This work only for rooted users !!!
use 2.30 version only. it has to work
go to the website of xda. everything is written there.
http://forum.xda-developers.com/showthread.php?t=1371345
I even downloading from market/ play store
Google Market/Play :
The search market work, but it’s not possible to download.
The application want to have an active 3G or Wifi network interface.
Some market applications are tagged "Wifi" only.
I can't fix this problem without changing low level API (ConnectivityManager/ConnectivityService).
If a developer can generate a Service.jar enabling traces in ConnectivityService class, he can send it to me.
To get around this problem, you can activate the 3G BEFORE starting reverse tethering,all the data will goes to the usb.
Tips : You can connect to some wifi hotspot not protected by a key.
It's only when you want to surf that the hotspot ask you a user/password.
But, at this point, we have an 'active' connection. Market download should work after starting reverse tethering.
The play store downloading also works as if we just have to keep the data connection active and then connect the phone to pc via usb and connect the phone in this tool and then download anything as i got 1.5mbps speed while i downloaded FB app and Google+ app from play store to check it it works and i am on 2G connection which gives only 15 to 25kbs on my cell and the PC is a broadband connected.
