Help Reversed Text messages
jkoby89
I don't recall when it exactly started but I'm finally fed up with it. Whenever I reply to a message notification now it displays my sent message above the message I'm responding to. It makes it really hard to follow the continuity of a conversation. Any ideas or thoughts?
Android Version
2.3.4
HTC Sense Version
3.0
Software number
2.12.651.8 71ORD
Kernel Version
2.6.35.10-g12b1a52
htc-kernel@and18-2 #1
Build Number
2.12.651.8 CL247025
If you are unable to get the OTA update from your phone. Use the RUU installer. Make sure you relock your bootloader (if you unlocked it) otherwise the RUU installer will refuse to flash your phone.
The RUU installer has been known to fix radio issues as well so your error 167 should go way assuming the phone hasn't been ported from a different carrier.
