Root Revert HBOOT-6.16.1002
I need to send my Evo back to Sprint. I'm still S-OFF with HBOOT-6.16.1002
Is there any way to revert hboot and get S-ON back?
Naters is correct. Thanks Naters for linking the appropriate files! :)
Flash the S-on tool from recovery. Next place the stock ruu on the root of your sd card. Be sure the file is named exactly PC36IMG.
Boot to hboot and the phone will scan for the file automatically. Select update when prompted, be patient, let it do its thang.
Select reboot, and ka-pow! You should be unrooted. ;)
actually this unroot method uses a PC36IMG file to get s-on. so make sure that you follow the guide. also make sure that you do not get the two files you need mixed up. they will ultimately be named the same so keep track on what is what.
