CapThrowback
Android Expert
Hm. If that's the case, your options are limited. Did you already try using Android Flasher to flash a recovery onto your device?No I don't have a card reader
How are you trying to install it (and which file is it)? If you're getting a message like that, it sounds like you're trying to install it in recovery, rather than in the bootloader.Does anybody know where I can get the PC36IMG file, every time I download it and put it on my sd card and try to install it I get a message saying the file is bad. Thanks in advance!
do you have htc sync installed?I am current trying to root via this method. Last night I was using a windows 7 computer and after copying the identifier token, the HTC site told me it was invalid. After several attempts I gave up.
Now I'm at work on an XP computer and I just got everything installed. I'm going through the process and now I cannot get Android SDK to run on my computer. I click to run it, see the DOS window flash quickly on and off the screen.
Does anyone have any insight on how I can get this to run on XP? I just want to get this thing rooted!
Am i unable to root without a card reader
Did you see my response to you yesterday?Am i unable to root without a card reader
I still need help
The latterhi there, i have read some of this thread, but not all of it... but i thought i'd stop and ask a question or two:
we are trying to translate method #3, the Tacoroot method, to the Mytouch 4G Slide, which is also in the position of having an OTA with a so-far un-S-OFFable hboot. if i undersrtand correctly, you are using the adb shell with root access(provided by the tacoroot exploit) to downgrade the hboot. and it looks like the flash_image program is facilitating the downgrade?
so i am wondering if your flash_image file is universal... i mean, would it work on the MT4gs also? in which case, we would simply do everything the same, except replace the mtd-eng.img with an S-OFF-able hboot for our phone??
if so, this would be great news! thanks in advance for any help.
edit: or are you actually lowering your version number so that the hboot will allow you to flash your factory firmware zip, so that you THEN can S-OFF the hboot? if that is the case, someone has already made a file that seems to lower the version number for our device... in which case we would use that in place of your mtd-eng.img file?
sorry for the confusion!
.hi there, i have read some of this thread, but not all of it... but i thought i'd stop and ask a question or two:
The latter.
If you have any img file of the misc partition for your device (I assume there's a way to pull it directly from the device), changing the main version is a simple matter of a hex edit.
So yes, the process is:
- use Tacoroot to temp root
- While rooted, copy flash_image binary to /data partition.
- Flash mtd.img file to misc partition, downgrading the HBOOT main version
- Flash an older stock RUU to device, downgrading HBOOT to a rootable version
i MOSTLY understand, lol. for me, the only question is getting the proper misc. image file.have you tried the android flasher way of getting recovery?
Make sure your device is booted in to FASTBOOT (should say "FASTBOOT USB"). In Android Flasher, after you've selected the recovery.img file, check the "I'm already in Fastboot" option, and you should be able to flash it successfully.Sorry its not loading right. Yeah I tryed this way aswell but it didn't make sence to me if you could help
welcome to the forums!!!!!!!!!!!!!!!Ok.. So I'm attempting the taco root method for the newest software update on my evo 4g at this thread:
http://androidforums.com/evo-4g-all...-rooting-gingerbread-2-3-5-dummies-guide.html
I get to step 12 and everything works just fine, the command looks identical, but when I try step 13 which is the --undo step, it says "adb not found" and I can't go any farther.. any help?! and Will my phone remain unstable, or will rebooting it at least put it back to normal until I can figure this out. Yes, I'm a nube, but I understand most of this process.. Any help will be greatly appreciated.
Yes.. I moved everything to the same folder and have been working out of it in the command prompt as it says... my screen matched that of his in step 12, but now 13 wont work.. buh. Thank you for the quick reply!
starting with step 1?
